T50
Oct 22, 2012 20:30:45 GMT -8
Post by Crash_X on Oct 22, 2012 20:30:45 GMT -8
i use a 80s model T50 in my 77 TE51, because i like how the shifter is a couple inches closer. drive shaft works cause trans is still same length. all is a easy bolt in swap. flywheel, clutch, starter are mostly swap able. watch for fork and through out bearings. theres a lot of different types. I try to stay in the same year as much as possible.
