Post by johnstoy on Apr 20, 2015 14:59:34 GMT -8
I have a 1979 TE51 SR5 and am trying to convert to electric fuel pump. I have tried mounting under hood, and it starts cavitating after a few minutes, I moved it to just forward of the fuel tank, mounted low, and it still cavitates after a bit. Has anyone else has any experience with this problem, or has converted theirs to electric pump? I am mainly doing it, because its hard to get to the OEM Mechanical pump, and its hard to get a NEW and not NOS mechanical pump anymore for this vehicle. I have installed countless electric pumps in other vehicles, and never had this problem. Thanks in advance for any help.
Post by Crash_X on Apr 23, 2015 19:55:50 GMT -8
Hi dude, first thing that comes to mind is a bad pump. elec. pumps do like it closer to the tank, as they push better them sucking the other thing i thought of is a rust pin hole in the pick up tube in the tank. i have seen it before, but not very often. try adding some fuel to get above the hole. elec. pumps have a short pump stroke, and mech. pump has a long through and might draw it past a small hole. but, i really dont know. let me know what you find out please ken
Post by johnstoy on Apr 24, 2015 6:07:52 GMT -8
Thanks for the reply. I did fill the tank full to see if that might be the problem, but did not help. The original mech. fuel pump has 3 lines, inlet, outlet, and return. Any idea what to do with return, and could it be my issue? Thanks
Post by Crash_X on Apr 24, 2015 8:51:43 GMT -8
the return line could cause it, not sure. try capping or run it back to the tank. maybe try run a temp line back to tank to see if hole is midway i have elec. in mine. maybe try Rock auto for a mech pump. they are cheap, mostly name brands and i was amazed at what parts they had for our cars. i got about $600 in parts for a tiny $260
